Ausinimio skystis...
Hool
Sveiki, planuoju pasikeisti ausinimio skysti (antifriza)
ir dabar skaitau manuala ir ten raso kad reikia maisyto su vandeniu Shock
Mix the recommended antifreeze with an equal amount of water in a clean container.
NOTE:s Always use Genuine Honda Antifreeze/Coolant. Using a non-Honda coolant can result in corrosion, causing the cooling system to malfunction or fail.s For best corrosion protection, the coolant concentration must be maintained year-round at 50% minimum. Coolant concentrations less than 50% may not provide sufficient protection against corrosion or freezing. Coolant concentrations greater the 60% will impair cooling efficiency and are not recommended.s
Do not use additional rust inhibitors or anti-rust products; they may not be compatible with the coolant.
kaip ta suprasti?
Ir koki patartumet lietuvoje pirkti?
http://127.0.0.1
vuojezau, nuvariau i parda kur visokiu tepalu visokiu antifrizu pilna. sakau man paty geriausia. dave kaskoki ruzava antifriza, sako sitas aliuminio blokui skirtas. 40lt sumokejau uz banke ir fsio. po shiai diena vazineju ir nieko Smile
